Grsemky
U.S. Navy Veteran
Arizona
Whaaat? So for us folks in Europe we only have obd
As far as I know, however with an OBD dongle and torquepro app you can monitor everything and more than what the access port is capable.. like I have one gauge that shows the heat soak from IAT at the filter to Intercooler and also tracks ambient
Italy
Yeah I do have torque pro as well but I'm not able to see the afr
Grsemky
U.S. Navy Veteran
Arizona
Newport Beach
Waste gate duty cycle, and yeah even in a stock tune it's good to track timing as negative corrections can be a sign of engine issues...
So I’ve been monitoring ignition corrections and WGDC and have been enjoying learning more about them. Thanks for sharing. I was wondering though, at WOT, should I be getting higher than mid 60’s% WGDC? I’m stock with the COBB OTS stage 1 91, drop in filter to be installed this Monday. Higher percentage=less open more boost as opposed to lower percentage=more open less boost right?
Grsemky
U.S. Navy Veteran
Arizona
Correct the higher the percentage the closer the gate is to being shut, resulting in more boost.. 60% isn't a sign of issue, our engines determine boost by the torque demand. If the engine is making sufficient power(cool air, good fuel) your boost request/WGDC will be less. What's your max boost been?
Newport Beach
Just over 20psi. For some reason I thought it’d maybe be more by 2-3psi. I also noticed ignition correction went negative on all cylinders from just below zero to -2.34. Positive numbers were pretty much all close. I noticed they’d go negative when I was just leaning in to the throttle. Maybe 30% or so. I know that doesn’t mean much without considering knock count. How long does it take the ECU to learn and adapt to the new tune?
