I thought about tenders and I have some, but the amount the spring bends at ride height has always bothered me.
With the spring rates mentioned above I only have to buy one set instead of two. HAHA. I have a bunch of 250s here, but after riding with the 650/700s the car is so nice to drive. Have you ever had any concerns about your rear spring combo popping out under droop or some weird driveway/parking lot transition? I am currently running a rear droop strap to contain my 6in springs.
I didn’t like the way the zero rate tenders handled big bumps - like a broken mattress in the back. They also felt squirrelly in the back when they unloaded. The 100lb tenders had the opposite problem - too much preload and the rear end would “launch” off of bumps. Switched them out for the 50lb tenders and it feels good - 75-100lbs of preload at full droop seems to be a sweet spot for keeping the springs seated and minimizing the transition lifting a rear wheel especially on rough roads.
Attached photos of the spring fully extended during install (with the old 225lb springs) and also at ride height, where you can see the main spring sits pretty straight and the tender takes up the angular misalignment. Don’t have a picture at droop for some reason.
The spring rubber is there (only on the left side) to even out frequencies between left and right as my corner weights are slightly heavier on the left with me in the car. Helps cancel out the lateral “sway bar wobble” you get going over a bump.
