cxwrench
Fitted my new 15x7 +42et OZ Ultraleggeras wrapped in Yokohama Advan Fleva V701 205/50:D. Very noticeable weight difference when lifting/mounting:cool:(y)
Saw those floor mats in your sig, they look really cool. How are they working out? Wheels/tires look (y) as well!
Thanks! Took the car for a spin and the ride is for sure improved. All the ripples, cracks and manhole covers are soaked up to the point I don't need to consider dodging them anymore. Turning is maybe slightly affected by the taller sidewalls, but the grip is the same. Without a doubt, I'll be lowering her later this fall.
Yeah, the KAGU 3D carbon-look mats are way cool. Got'em on Ebay. The fit is perfect and the velcro type backing on the underside keep them stuck in place. Minor wear spot from the clutch pedal. I only bought the fronts, but based on these, the backs have to be perfect.
maestromaestro
Updated my signature and changed the insured value from whatever the insurance company thought I had to the 'agreed value'. No change in the rate, surprisingly.
Hypergram
Today, after 2 months and 3 failed attempts I finally got my RMM on the car. It's a ARW a88 (medium softness). The vibrations from a stop are insane, but I guess it's supposed to be like that? The parts itself already has 5,000 miles so it's already run in. Just happy to get it on tbh.
cxwrench
Why so hard to get it mounted?
Sam4
Front brake time. Stoptech rotors and Yellow Stuff pads. I ordered on Saturday - got the order today/Monday - WOW!
Thanks Ron at Whoosh!!
Hypergram
Let us know how those brakes work out for you! Eventually I would like to swap my OEMs out and all info is appreciated.
How does that paint hold up to the heat in the engine compartment?
I drove it today 30 miles, engine got good and hot. No issues, looks as good as it did before. I'm confident the paint will be fine
danbfree
OK, so not today, but projects over the last couple of weeks finally done. I was given some heat blanket material so I bought some heat tape and wrapped the upgraded aluminum crossover, using blanket right in the middle where it's right above the turbo. Helped with charge and even coolant temps just doing this first...
So then I installed a Pwnall Performance intercooler. I painted the support/crash bars black with a bit of rattle can flat my buddy had left and shaved the grill with a RotoZip tool. It's far from perfect, I need to hit the grill with some gloss black to get the areas I screwed up. But wow, what a difference in charge temps and cooling overall, I need a wash now after enjoy the intercooler for a couple of days on my e50 tune!
I wrapped my cross over pipe in gold reflective tape and noticed a difference for sure, paired with the Ron's V3 Intercooler even in this heat, cruising I stay about 5-8 degrees above ambient. Out performs the stock core in every way
dropped my fist off for a hit and run repair on the rear bumper and after enterprise scheduled me to have a Jetta they roll out a Kia Soul that someone obviously smoked in (n) luckily I am supposed to have my car back Friday with a new bumper.
I got surprising wheelspin in 3 gears. Mission polish off OEM Michelins before winter is well underway.
danbfree
Yep, my intercooler is exactly the same as Whoosh V1 and Depo and I have no regrets... even for the low end it's a very decent piece that works well. Yeah, can heat soak a bit in stop and go but barely goes up at all on pulls, just love it... and a lot of people don't know, but a crossover alone is good for 10 torque, but gotta wrap it with heat tape at the least.
danbfree
Me too, kinda... just killing the stock all seasons for new cheap sticky ones at least, LOL...
Been thinking about doing this with the crossover pipe for a while. Maybe just the bottom half of it least
