Thread Starter
#61
Thread Starter
#61
Try to grab the tab from the underside, that’s where you will have room to fit something in there. You’ll see once you get the first one out, there’s only one area that you can pry, everything else is flat and you cannot get anything else in there. Once I got the first one done the second one went really quick. It’s just a pain in the butt but keep at it. That Ukrainian guy in the video above doesn’t actually show how to do it on the video he just shows you the aftermath which tells us that he probably spent a while getting it off because it just takes patience. Same with the tabs, he just pushes a screwdriver in there and it pops off in five seconds but in reality you have to work at a little bit. I suspect he got it off and then gently placed it back on to make it look quick for the video.
