I don't believe my car has stock dual horns, last time I was in there, I only saw one! My complaint is definitely volume. During my road trip across the country, I can't tell you how many times people drift over into the left lane while you're passing them, including truckers which is largely terrifying in a small car. [emoji38]
The Mountune Triple Pass Radiator seems like the best solution for the higher temps that we see out here in AZ. If that doesn't do the trick, I'll experiment with water/coolant/additive mixtures and worst case scenario pull the VelossaTech Big Mouth off of the car, though I'd rather not.
I bought the BD Back-lit Dead Pedal to have a good place to rest my foot that doesn't wear through the carpet over time. It's also pretty dark in the area where the Dead Pedal is and I always end up banging my feet around when driving at night, so I figure a little extra light to the left of the pedal box will help. Also, it looks cool! [emoji38]
I was not prepared to add the second horn (to the driver's side) when I did the IC. Now it will be a pain to add it and run the wire, but I'm not removing the nose just for it.
I added two horns to my motorcycle just in front of the radiator and they were pointing downward at a forty-five degree angle to each side of the bike. They were specifically for those Lane changers you speak of.
Sent from my SM-T860 using Tapatalk
