FORScan reverse/backup camera discussion thread
XanRules
Okay, I'm having the same issue a few of y'all are having but in skimming the thread we didn't find the solution.
I haven't installed my backup camera so this might have worked and I'll know once it's enabled, but I have a 2017 that's been upgraded to Sync 3.4. The settings spreadsheet says to change the values to
2330 6105 C052.
However, my default values were 0130 6505 0074. We changed it to 0130 6105 C052 and nothing broke - hell, once I wire up the camera it might have even worked - but I'm curious as to what happened here that made those values SO different than expected.
When I programmed my backup camera, I changed X1XX XXXX XXXX => X3XX XXXX XXXX (where X is your current value i.e. leave it alone).
As far as I understand, different configurations of the car will have different default values.
XanRules
Interesting! We will try that if the backup camera doesn't work when I install it - nothing broke changing the 5 to a 1, so that's good at least.
Did you ever get it figured out? I’m still at a complete loss here. Even if you didn’t get the camera wired up, it should have said something like “no camera detected” when you put it in reverse after programming it.
XanRules
If that's the case, then no, because I don't have it wired up yet. I had a local guy with a laptop and FORSCAN knowledge do the programming (or whatever) with me, so next time he's available we can fuss with it again. I do intend to have the camera wired up this month, though, since my wiring harness finally arrived, it's just... well, you're in Oregon, you know what the weather's been like this week.
Just got my ST last night, it's a 17, so no OE camera.
Did any Fiesta models [18-19 STs?] have a backup camera as factory? Anyone tried to install the OE instead of one of the aftermarket options? The Amazon option is only $30, so that would be the way I'd likely go, but an OE install would be nice if the cost isn't a significant difference.
A quick Autotrader check found a 2019 here in Houston with [assuming] OE backup cam. Looks like the OE setup is also on the hatch release handle.
Part number D2BZ-19G490-E comes up when searching the parts catalog for a 2019 FiST. I assume you'd also need the bracket, and maybe a new hatch release. Easily >$100 that route.
My dad has a 2019, and the OE setup is not on the hatch release handle. It is next to it. In fact, it'd be more difficult to set up an OEM one in a 14-17 hatch, as the piece the handle mounts in has different cutout placements on 18-19 (hatch release handle is moved farther left of the Ford badge). I was looking, and an OEM backup camera would cost significantly more than getting something aftermarket on Amazon. I would suggest one of those you can find on Amazon that has the camera integrated with the handle, OR you could go for one that's integrated with a license plate light (if you don't mind the camera being wayyyyyy offset).
Thanks for that. In that case, I'll likely go with the option that integrates with the hatch release
Capri to ST
Yes, 18s and 19s came with a backup camera standard from the factory. I believe all cars were required to start having them beginning with the 2018 model year.
When i did mine last year I tried the hatch release camera from amazon. The camera perspective was horribly off and had a bunch of other issues. I swapped to the license plate one and it was a lot better. Unfortunately the hatch button one requires irreversibly modifying your car to fit it, so now the OEM hatch button fit is loose.
I should also mention the license plate light camera is now failing on me after less than a year and I am going to have to take it apart and replace the camera again.
Luck of the draw, I suppose, with these inexpensive cameras. For the cost of doing an OE setup from a 2018-19, you could probably pick up 3-4 of these cheaper cameras.
This is probably top of my to-do list, even though the FiST is significantly easier to park than my former R57 MINI Convertible.
I would try your local junkyard, I have a few 2018-19 fiestas in local yards... It doesn't have to be an ST trim, it was standard for all fiestas in those years
Any ideas why sometimes the screen keeps in blue and doesn’t change to radio automatically? It needs the hand brake to cut and see the radio
XanRules
I finally have mine wired up, but I've got a suuuuuper glitchy screen that then just fades to black. My thinking is that it's most likely a bad wiring job since I had to cut the RCA cable and then re-solder it when I installed it, but I figured I'd check in here.
2016 Fiesta ST on Sync 3 2.2 w/ GPS
I'm trying to enable the backup camera through FORSCAN and have gone through rewriting 7D0-01-01 to 2330 6105 C052 but I still get no response when shifting into reverse
The screen should have some response when shifting into reverse even if the camera isn't wired correctly right?
The only other things I can think of that might effect it is that the car thinks the doors are open and I have no airbag installed since I am messing with my window regulator and steering wheel at the moment
With engine running or not running, going into reverse does not pull up a backup camera screen
Also I tried changing 7D0-02-01 to xxx xBxx xxxx to get the ST splash screen, that also didn't work
This APIM has been giving me issues since I've bought the car a couple months ago, Android auto doesn't work, Syn3 updater doesn't work, and I can't get my back up camera to work, I'm thinking of just buying a reprogrammed APIM off eBay at this point.
Did your car originally come with a sync3 or sync2 and was upgraded to sync3?
It might be worth starting over with your As-Built data and doing a factory reset on SYNC 3. It seems like the previous owner may not have known what they were doing and could have changed something incorrectly. At the very least, the ST splash screen should still be working.
Also, can you describe how your camera is currently wired?
I purchased this set off eBay https://www.ebay.com/itm/235634392751
From what I understand, it has provisions for getting power from the headunit OR from the reverse light
I have it connected to what I think is the reverse light wire. When I peeked behind the brake light, I saw that the reverse light wire was orange, so I tapped into the orange wire on the harness and the adjacent black wire for ground
The video signal wire terminates to an RCA connection but it was going to impossible to snake it into the cabin with the connector intact, so I snipped it off and did the best job I could resoldering the 3 tiny wires once it was in the cabin
Then I bought this adapter to connect to the OEM harness and the camera is connected to the adapter https://www.amazon.com/dp/B0BKQ9FFK4?ref=ppx_yo2ov_dt_b_fed_asin_title
I will have to look into factory resetting SYNC 3 but at this point I need a long break from working on this thing
Did you snip the green wire to change the signal from AHD → CVBS? Sync3 only works with CVBS.
Also, my connection to the brake light looks like this.
Also, you can most definitely snake the RCA wire with the connector intact through the cabin. I did it (and many others) – you just need A LOT of silicone lube. Slides right through the rubber sheathing like butter.
Forgot to answer previous post, AFAIK this car came with SYNC3, that's at least what it was set up as when I bought it
Checking through the settings, I see that there is a camera settings option now for camera delay, but still no response when shifting into reverse
Changed my wires to tap into that purple/black and blue wire like in your picture, and even checked them with a voltmeter, but still no response
Even if the camera isn't set up correctly, it should still be doing something when I shift into reverse right?
On a side note, tried programming a keyfob through FORscan and that didn't work either, said no key was detected
AFAIK the keyfob I bought is the correct FCCID, tried 5 times with the key pressed against the steering column in various positions
This car is kicking my ass
