Mikey456
Los Angeles
[thumb] YES, I am still on the factory suspension, and those were one of the first things to go on this car for me, right after the symposer delete and engine heat retainer (cover)! [wink]
Is it easy to remove? Looks like one bolt holding it on. Do u need a spacer when putting the bolt back in without it? Have not seen much on the forum about it.
Erick_V
Texas
You only need to remove the nut. I believe the threaded portion is in the weight itself, you remove the nut and it's free. You don't need to do anything else
DangerMouse
Illinois
Got bored and I've been wanting a finishing piece for the intake feed, so I hacked up the stock air box inlet. I wrapped it in reflect gold tape but it started peeling after a few days, I'm debating painting black. It's the swiss cheese piece hahaha
Minnesota
@TyphoonFiST Might not be a Rocket Box, but hard to beat $25 at the thrift store, complete with instructions and all hardware. Looks like it was used a handful of times.
Test fit for a couple of longer trips coming up.
Where’s the propeller? Disclaimer: This comment was made in jest
Minnesota
For sure! Tires should be here Monday, I'll have them mounted Tuesday. 225/45/16 ZIII! Gonna sell my current setup. Yay for traction! (maybe?)
Traction? Lol they will stick like glue and you will wonder why you waited so long. Total transformation
maestromaestro
Houston
Sumitomos? I have them on my 993. These are good street tires, but they are STREET tires.
Pharr, TX, USA
Dropped in an ITG filter and I loaded the stage 1 93 MAP. I also installed the AWR 88a RMM and a whoosh symposer delete.
What a big difference in feel and performance![lovest]
Next on the install list: whoosh v1 or v3 FMIC, whoosh silicone intercooler set, whoosh hot side j pipe, mountune induction hose, whoosh crossover pipe, whoosh v2 turbo inlet, GFB DV+, one step colder plugs, and a stage 2 MAP from Stratified or Dizzy.
