Installed my Whoosh quick shift, I set it at 25% reduction, put some blue loctite on all the bolts. I’m just skeptical the shifter might come out of the ball thing but it should be fine right, it just looked like it was at an angle but when I took it for a drive wow it def made a difference. The shifts feel tighter, before I had a vibration in the shifter in second gear, now it’s stiff as hell. Def happy
PunkST
Got my clutch pedal stuck to the floor again. And once again it came back and hasnt repeated today. I think im over extending. It when i push it all the way down. Or my pedal box is bent from when i hit that deer.
PhoenixM3
Said good bye to “Storm” my 2017 FiST which was totaled 2 weeks ago.
Business6
Forgot to post I rotated tires, did new balancing and got an alignment as I was experiencing vibration at certain highway speeds. I should have done the alignment earlier but it is much improved now.
the duke
Put on my Nelson Ledges track decal on the rear window.
Next is hopefully Mid Ohio in a few weeks.
Fiestig
Installed seats. Need to route the belts, but I am not entirely sold on the look. I think I will make my own covers out of spare standard st seat cloth. What do you guys think? They are actually pretty comfy. I am just not huge on blatant branding. I like a bit more subtle inside
The branding thing does not bother me all that much, but I would've wanted seats with the bolsters a bit more 'cut down' in the belt area, so that you could use the factory belts OVER the seat, instead of threaded through belt holes.
Why I will go with one of the better race shell style 2 piece recliner/folding seats when I ever change out the base chairs in mine.
Fiestig
I already started cutting new seat foam to raise seating position a bit and I marked off to dremel the back quarter of the lower seat for a pocket to allow the seat belt to remain as is.
In short... For the most part I agree...lol
SteveS
I actually kind of like the design. Reminds me of my old Recaro spectrum stripe seats in my 1978 Fiesta.
Well ....anyone who has issues with the V-band on a ATP system let me know....i figured it out well. I used there newer design style this time around. But I'll tell you what....God dam V-bands man. At least I got to drive my Typhoon to the Hardware store! Ironic signage at the store also! Hahaha
PunkST
Car lost all audio output to the speakers today.. Then just as weirdly 20 minutes later it came back.
Going to have to replace high pressure pump on the gti. It didnt make it down the street today
