Got my second revision and went from making 13[si to 17psi. Already feels much better. Car is still doing that abnormal bypass valve venting but my tuner says thats the ECU reacting to the higher then stock boost targets. That will be tweaked some more and is already a little better then the 1st revision. Ill just roll with the maps as I do each revision untill shes dialed in. I also found this gem of a brake kit 2 hr away from my area that I'm scooping up on Sunday. Guy is asking $700 for the whole kit and they clear stock wheels with a 15" spacer included.
