Changed the oil and washed it thoroughly. My precious today has hit the 120k mark. It is my secind daily driver after Chevrolet Malibu which was bought last year on abetter.bid at some fantastic price I couldn't but buy it.
Finally got some time to put this S280 back together. It’s a shame no one will be able to see it once its installed because it looks so damn sexy in black cerakote!!! Hoping to have some time for install this weekend.
Good luck trying to locate Exhaust leaks on Black cerakote* I know i do!
Thanks TyFist. Im definitely good at making everything more difficult then it needs to be for myself. Im assuming you definitely didnt have an issue yourself with this😂
The only way to tell if the exhaust is leaking is wiping your finger across the surface. Its what i do! But only when its cool or you wont have a finger print anymore*
Thanks TyFist for the pro tip and for looking out for whats left of my finger prints🤘
Finally got one of my Radium catch cans installed. Passenger side doesn't fit with the coolant tank getting in the way of the lines. Might do a Mishimoto on that side instead and sell the Radium kit I have. Driver's side fits really well and wasn't too bad of an install.
What coolant reservoir do you have? Also how was the install of driver’s side? I installed the passenger side years ago but been procrastinating the driver’s
I have a pro alloy coolant reservoir. Passenger side required cutting up the stock pcv line a bit but the install is pretty simple. Can mounts to the ECU mount studs.and is tucked away in the back by the induction hose.
Awesome, thanks. Now I know what reservoir not to get!
Finally had the right adapter to install my Billetworkz Fusion Blue shift knob. My barrel stickers arrived for my wheel restoration so they're one step closer to being mounted. Next up is ceramic coating and then getting the tires mounted!
Got one oil leak dealt with an oil change and tires rotated. 2nd oil leak is either gonna cost me $655 (valve cover gasket) or I can suck it up and tear into it my self. Anyone else deal with the valve cover gasket and any tips tricks on whats gonna be involved because damn ford seems to like to make simple things complicated lol.
You did a 4x100 conversion/hub drilling?
