Spring, TX
Got it, my dad just got a steal on a Yakima box for their Outback [with the handy built-in rails].
We've got an Expedition Max, so it's unlikely that I'd ever really need the extra storage in the FiST. But good to know.
Cneu
Hillsboro, Oregon, USA
I probably wouldn't have it if I didnt get the box for free when I bought my latest tercel(photo attached). It's kind of useful sometimes? It's good for dirty running clothes and wet camping equipment. Keeps the smell out of the car.
Am I tripping or did I shear my transmission mount? Will update once I got the battery removed 😬. The whole engine jerks and I see my shifter wiggle about an inch and a half during stoping and starting
Are you super hard drag race start launching it on very sticky tires?
TONS of wheel hop if/when you do??
I've never seen or even heard of that happening in these cars in the almost ten years on this forum and nine years of owning a FiST
Houston, TX
I've never seen it nor can I find anyone who's had this issue online. It's been raining so I'll get to look at it tomorrow.
I had cobb tc on 4 with cobb stage 2 tune and launched the car from 4k rpms. Drove the car home the remaining 4 miles and didn't notice anything (but I just got off a long shift and was tired ). Turned the car on today and right away noticed the shifter wobbling a shit ton and when I went to drive off CLANK CLANK and all the vibration so I parked and checked.
Car has an LSD and stage 3 clutch with SMF. Stock turbo. Really shocked this happened tbh
What Mount? OEM?
Battery acid may drain onto/around that location. Road salt, sediment stream in from underneath headlamp and settle in that area.
Pay attention to the ground wire sitting underneath the battery box, exposed to that battery run-off. It rusts, you can't fix that; can only add other(s) some place else to augment it. Had to do it on the prior car when it started to burn-up alternators.
Hopefully the frame/threads are okay.
Houston, TX
Bent my RMM as well since it dropped. I'll be replacing all mounts with VibraTechnics probably. It appears the failure was due to forgetting one of the 4 bolts? I torqued the 3 bolts to spec and used blue threadlocker. One bolt I know I forgot to put in(as I found it in my pile of bolts), the other bolt must've backed out while driving
Houston, TX
My only other guess is I over torqued those two bolts where it snapped. Or maybe since my mounts are shot it had so much movement it snapped
Cneu
I'll say it, that fucking sucks.
what I did today: cleaned the fiesta after a week of camping in southern/central oregon. I love how easy to fist is to clean with a vacuum, except for between the front seats. I also re-configured that rack thing that I built so the boards stop falling out of the middle. I used some ratchet straps to get everything tight. I'll probably need to order heavier-duty stuff for this t-slot. The cheap amazon kit I bought uses cheap powdered injection stuff which means if there's any slop in the frame it'll bend and break. Already broke one of the 90degree brackets.
Next upgrade for the rack thingie is to make another section that can go where the passenger seat is. Then I can sleep in the lil beast. I'm 6'1" (6'2" in the morning) so it'll be pretty funny. I live in the PNW so winter camping means dealing with a lot of rain, so sleeping inside would be rad.
Tom Mackinroy
Military Veteran
California
If you’ve just passed your test congratulations but brace yourself for insurance quotes that sting The average 18 year old in Birmingham pays over £1495 a year and that’s before adding any optional extras best quote Still there are smart ways to cut costs like choosing a modest car adding an experienced named driver or going for a telematics policy which rewards smooth cautious driving with lower premiums at renewal Always shop around even if your first quote seems reasonable
Finally got around to swapping my cabin air filter today, can't believe I let it go that long, thing was absolutely disgusting. Also gave her a good wash and noticed my passenger side fog light is flickering so that's probably next on the list.
GA
Changed my coolant reservoir tank that was leaking and nearly left me stranded after overheating. After driving a slow truck for the week, the FiST (on E30) felt like a rocket ship
I did that this week too. And the lower clip on hose that goes from the reservoir to the back of the engine (turbo). The hose had broken right where it goes into the coolant reservoir. After 9 years and 187000 miles I guess that's to be expected.
Grsemky
U.S. Navy Veteran
Arizona
Finally had some time to shape the spoiler, there is a lot of voids so I need to build up some areas before I smooth with bondo and cover in carbon... But I think this is the final shape I think 1000009976.jpg 3a8b4460-1725-4792-8940-23b82fefcb6c-1_all_23786.jpg
