pixelzombie
Chicago, IL, USA
New brakes and fluid but most importantly I finally rolled my fenders after dealing with the scrape into my drive... The car is gonna feel brand new for the new year lol
I'd be arrested if I tried doing that in the parking spots where I live!
Are those DBA rotors in the front??
Grsemky
U.S. Navy Veteran
Arizona
Lol if I lived in an HOA the cops would've already been by, ask me how I know lol
And they're not DBA rotors, just some cryo centrics I found milled... The guy only made a few sets so I'll probably switch to DBA when these go
Ricky_Bobby_24
Active Duty U.S. Army
USA
How much of a pain was it to swap?
Not too bad. Took 15-20 min total, ever since I got one of these.
Just remove passenger center console side panel. And between This tool and a screwdriver, take off the 5 Torx screws.
personally that hardest part was getting the new filter in without crushing it too bad.
Spring, TX
Guess I need to add that to my things to change when I do the oil in the next weekend or two.
Oil/filter, install Fumoto valve, both O2 sensors, check air filter, change cabin filter.
Have the Fumoto & O2 Sensors, need to get oil & filter(s)
SE, PA
Your annual PSA to change the cabin air filter.
Just changed mine before the snow storm hit. Pretty crazy for not being in a dusty or dirty area and only 11 months old. View attachment 68968
I just did mine the other week. I usually take out the glovebox and the one HVAC tube that is in the way. This time I only put the lower three screws back in to help simplify the process when I do it next time. Five screws to hold in a cabin filter seems like overkill to me.
Grsemky
U.S. Navy Veteran
Arizona
No leaking with the blower on?
AthenaAutocross
U.S. Navy Veteran
Washington
I'm a big fan of pairing my Dewalt Gyro driver with the Harbor Freight 90 degree for these sorts of jobs.
This thing has gotten me out of so many painful situations.
https://www.harborfreight.com/right-angle-magnetic-bit-holder-drill-and-driver-attachment-58223.html
Grsemky
U.S. Navy Veteran
Arizona
Ricky_Bobby_24
USA
I use to have something similar but relied on it too much to pull off an over torqued screw and it grenaded. Never got a replacement but definitely still need to.
Ricky_Bobby_24
USA
I also forgot to post it, but recently replaced both axles and seals after my driver side started clunking and both seals from my clutch job in June started leaking. Think it was caused by my “helping 2nd set of hands” just thrashing them in while not being flush. These replacements have not leaked once. Tried out some Ravenol MTF 75W-80 this time from Motul Multi DCTM. everything feels great so far. IMG_3402.jpeg IMG_3404.jpeg IMG_3405.jpeg
Sam4
West Chester, PA, USA
embarrassed to say I paid Ford to replace my valve cover (most cars - just a gskt change). Long term gskt leak started to smoke into the cabin, and too frigging cold the last 2 weeks...
Houston, TX
It happens man. I feel stupid I paid 2300$ for a timing job when I have done it myself multiple times
Kalamazoo, MI
Went in for an alignment and found I needed both lower ball joints. $800 for both arms or $500 in tools and $250 in parts makes much more sense. Gave me a reason to pull the trigger on those shiny HF tools. Also picked up a blend door actuator as my vents won’t defrost.
Removing the old arms was a pain and led me to pick up a map torch and a pickle fork. Got it off in 10 mins with the new new tools.
I’m a big fan of new tools if you couldn’t tell.
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
More of a PITA than it should be for something that should be changed on a regular basis. But if you have some basic mechanical skill you'll be ok.
I've got mine programmed in my maintenance app for annual replacement. The Rabbit gets one every 6 months due to rallycross useage.
AthenaAutocross
U.S. Navy Veteran
Washington
Went to replace the bushing for my AWR RMM, Sucker was seized on there and stripped out when I tried to remove it. Had to take it to a local shop who welded a bolt to get it out for me. Not sure what the heck the previous shop did when I had the motor replaced, but this thing was not coming out under normal means. (Though, it could be bent since I'm pushing a lot of power and am quite hard on the car for autocross)
Replaced the hardware with the Whoosh anodized bolts.
