SteveS
Osage Beach, MO, USA
Ever since changing to step colder ngk plugs I've been having misfires under full throttle. I gapped to .026(originally .030) and it's much improved but still misfiring a under wot. I'm in dizzy e30 tune. He suggested I gap to .028 which still wasn't enough. Should I go back to OEM plugs?
If step colder plugs cause misfires, yes, the answer is to go step hotter. The fascination with step colder plugs eludes me. It is not a magic formula for power. If, after your tune, the engine was running fine without preignition, and a plug check did not show signs of plug overheating, then there is absolutely no reason to change to colder plugs because the only expectation would be that you would have misfires, fouling, and eventual problems from unburned fuel.
Houston, TX
I'll try my OEM plugs when I'm off Sunday and check what their gap is at. If I am correct a -1 octane adjust ratio means no knock? I've also never had negative ignition corrections with my OEM plugs. I do want dizzy to tune it up to the max when I get my revision tho. So I'll try tightening the gap to .024 as well, but if I'm tightening the gaps just to make the same power that sounds counterintuitive
Houston, TX
FYI if you're doing the focus coil conversion do not get denso coils. I thought denso was an "OEM supplier" so it would be fine. SVTdesignFab recommended Bosch and I should've done that. The connectors on the denso coils are straight which makes it a hassle to install as they make contact with the adapter plates. The Bosch coils are slanted up so you can connect them easy. I got some Bosch coils on the way and I'm guessing that it's going to fix my high rpm misfire issue as well
Grsemky
U.S. Navy Veteran
Arizona
What did the coils run ya?
Are the Focus ST coils that much higher output than our OEM?
If not, what else would be the reason to swap to them?
Atlanta
New tires are on, RE71RS 205/50r15. They are downsized from the RT660s I ran last time which were 225/45r15. They should be able to hold most of the power with the diff, but I'm still expecting some wheel spin if I apply way to much in 2nd. Went less wide this time to try and see how it helps with response. If they just don't work out I'll probably just start looking at going flares so I can fit something much meatier.
Are those the TD Classic Pro Race 1.2 wheels? I want TD wheels for my next set but am torn between them. Stock suspension?
Atlanta
Paid all my new-turbo money to shop to replace clutch and slave cylinder. Had to pay double labor (and two slave cylinders) because the first one (OEM Ford unit) failed spectacularly and bled out all over the bellhousing so shop had to redo the work. Mechanic certainly ate good that day.
This happened to me in September. All the money I'd saved for suspension mods went towards replacing the clutch and slave cylinder for the second time. God it was frustrating
Atlanta
Oil change with Pennzoil Ultra Platinum 5W-30, and transmission fluid change with Ravenol 75W-80 MTF2. Bought a titanium magnetic oil drain plug and Greddy magnetic transmission oil drain plug from Whoosh a while back and finally installed them too.
Houston, TX
They have twice the windings so they can sustain higher voltage easier. It's not a necessary mod as our stock coils do fine. But when you start doing higher boost and sustained high rpm it can perform better and lasts longer for the same price or cheaper. It also can make your idle smoother although I haven't noticed this
Downsy
U.S. Marine Veteran
HUNT COUNTY TEXAS
Been having intermittent issues with the purge valve for the last few months. Finally bit the dust on the way home the other day. Did the juryrigged replacement using a Motorcraft branded Bosch valve from Rock Auto and some 3/8ths tubing to splice in the new valve.
Those are the original TD Pro Race 1.2s and the size on AA's ride (15x8, ET 35?) are the ONLY ones left which are able to be bought NEW.
Used, they might be found in 16x7 (very scarce), 17x7 (slightly more common), and 17x8 (moderately scarce).
The original U.S. importer (who was on this site frequently) was trying to get TD to cast 16x8s for us, but they refused since the demand did not seem to be overwhelming enough for them to bother.
AthenaAutocross
U.S. Navy Veteran
Washington
Original TD Pros. I got 2 used on ebay and the other two were the white and silver from Phils Tire, which is why I have 3 different colors. Not sure if he had any others left. And stock suspension with 91k miles on it, only a Whiteline rear sway bar and some Moog camber bolts up front.
Sydney NSW, Australia
Chased down an exhaust rattle. Exhaust shop years ago didn't refit a nut holding on the heatshield (only 1 nut). It rattled for a short while then nothing for about 3 years.... now it's back!
I bought a flanged serrated nut hoping it'll just keep it it in place as all the others are present.
Atlanta
They look great.
