- Member ID
- #1040
- Messages
- 669
- Likes
- 344
So, I thought I would share part of where I am going with this. The ring is made of 6061 billet aluminum. Why? Just because. Nothing like mounting a speaker to a solid surface and if you have to mate it to a solid surface why not make it pretty.
The sub, a Morel Ultimo 2 ohm. This thing comes with a 5" voice coil and is capable of handing 1000 watts normal load and 3000 watts peak. This is how you build a subwoofer. For those who are curious this is a sound quality subwoofer.
So in my setup there are two of these. Normally under a 2 ohm load, this would double the output of the amp, but the amp is configured in a way that it puts out a 4 ohm load worth of power, even when it sees a 2 ohm load. Each of these will receive 500 watts of 4 volts worth of signal at 14.4 volts of power. Yes I am adding weight, but I am also removing the full size spare tire. So with the box, it will not quite equal out, but it will be within 50 lbs.
