Mesa, Arizona, USA
I just had to do my driver's side for the first time, it was stuck on the front dash outlets😮‍💨
Fun! I haven't had to replace that one yet, but I did my recirculate door with a dorman part about two weeks ago, and one of my two screw holes were stripped. The joys of an 180k mile car. :)
Grsemky
U.S. Navy Veteran
Arizona
I actually just used a cheap one since I figured I'd be in there again anyways and it was same day delivery... It took forever to defrost my windshield during that one week of winter we got
Mesa, Arizona, USA
Dorman was very fast delivery on Amazon and basically the same price as it was on RockAuto so I figured I'd go that route... plus they'd replace it if it broke as it has a warranty (i believe)
Capri to ST
CHAPEL HILL, NC, USA
My driver's side actuator, the one that determines the air direction, went out for the second time about 2 weeks ago. While I'm waiting for my garage to get a part fortunately it just clicks for about 10 seconds before and after you turn the HVAC on and then stops. Those little suckers are loud.
Grsemky
U.S. Navy Veteran
Arizona
Yeah I think it was like 2 day shipping, but I was impatient lol
Spring, TX
103k on mine & no issues that I've noticed. Unknown if they were ever replaced by the PO.
Now, if I could get the auto A/C to work at normal settings. Auto @ 76* seems to be 'normal' as compared to 72* in my Expedition.
rallytaff
Los Angeles
I hardly ever use my A/C. I only use it if it gets into triple digits. Normally, I use the free air from outside!
Spring, TX
Too much humidity in Houston for that, most of the time.
I'd noticed that Auto @ 72 it would run at max AC at startup, for a minute or so, before settling down. And would still ice you out. 76 seems to be the happy medium, which just seems inaccurate compared to all my other auto AC equipped cars before. 72 was always the ideal setting.
Spring, TX
Painted the chrome on my wheel. Rust oleum 2x satin black. Not sure if I should've went with flat black? What do y'all think?
Also used FORScan and changed my tire size. These light wheels feel so much better
That looks great, have thought about similar. Is that part removable? Or did you do it in place?
Houston, TX
I just manually set my AC 🤷🏻‍♂️ It's what I'm used to doing.
Yep. You use some kinda stick to push the airbag release springs, on the backside of the steering wheel. Then use a Torx10 bit to remove the chrome part, again on the back side. Then a T8 to remove the buttons so you can paint.
Next imma remove the ST badge at the bottom and do something. That one just pulls out with glue
Grsemky
U.S. Navy Veteran
Arizona
That actually looks fantastic, I've been pondering a custom wheel but that might just scratch that pitch
Houston, TX
Same bro I was looking at the custom wheels until I realized I could get a used turbo for that price (800$). So I decided I'll black out the chrome and maybe get a sew on steering wheel cover or maybe vinyl stitch a racing stripe
My girlfriend says I have chickens living in my dashboard every time I start the car, shut it down, or change any of the HVAC settings! [histerical]
Spring, TX
Thanks, doesn't look too bad. Maybe after this winter-pocalypse we have coming this weekend I'll look at that. Did you pred the trim at all, or just wipe it down & paint?
I've also been debating changing up all the ST badges, steering wheel might be a good start. Match the surround to the wheel trim & change the ST script color.
Houston, TX
I sanded with 80 grit then wiped it down with alcohol that's it. You could probably sand with a less aggressive grit that's just what I had laying around lol
Kansas City, MO, USA
Put on a skid plate from ADF Customs.
I added the "labels."
I put it on mostly for aerodynamics- I suspect it will enhance downforce. I have 1/4" ABS sheet that I'm going to put on the remaining rough spots on the underbody.
San Diego
Damn that looks good. Maybe after I find where my oil seep is coming from I'll get one of these.
I put on new Brake Pads (Ford OEM) and Rotors (Powerstop Drilled and Slotted) and finally did the Shifter Base Bushings while the Fiesta is in the garage. Have the fluid and new Stainless Steel lines but will probably do those closer to a trackday (Just to have fresh fluid). And before people ask why OE Pads, if its good enough for ST Octane Academy its good for my ratty old Fiesta.
AthenaAutocross
U.S. Navy Veteran
Washington
It should help reduce high speed lift, like 90+mph. It's something I've been looking at lately.
